New GT transmission grind
RubyRedVert
Zeeland,MI
2015 Mustang GT Convertible
Purchased a new GT convertible 3 weeks ago. The car has always had a slight grind while shifting into 4th. Does it every time in the morning (Oil temp cold). As it warms up, it will go away under light throttle shifting. But it will grind into 4th under heavier load like passing a car, or higher speed when merging onto the interstate.
The dealer initially told me the transmission needs to "seat and let it loosen up". I'm at 1000 miles now, and it's still grinding. My gut tells me it's a synchro issue and needs to be repaired. Anyone have similar issues? Was the transmission rebuilt or replaced?
ksiefken
Austin, TX
2015 GT w/ PP
I had the same issue on my 15 GT PP. Especially when cold, I would get a little nimble, grind going into 4th. I could time my shifts a bit to minimize it, but it happened more often than I liked.
But... I am going to have to agree with the dealer for the first time in my life. The MT-82 seems to need a significant break-in period. I'd say at 2000 miles or so I noticed the transmission behaving much better. Cleaner shifts, less noise and less nibbles. at 7k mi, I get a nibble into 4th every other month or so.
Hope this helps.
RubyRedVert
Zeeland,MI
Hope this helps.
Very helpful, thanks for the reply.
I guess I'm struggling with dropping $50k on a brand new car and having a transmission that grinds. Went ahead and made an appointment for tomorrow morning.
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
Change the fluid http://www.mustang6g.com/forums/showthread.php?t=48679
Then get a aftermarket shifter.
09jsw
East coast
2015 Guard PP GT
My trans felt like complete garbage until I hit 7k miles and got the mgw shifter. It's perfect now. I'll end up doing a fluid change later this year to reinforce that. It really does seem like the trans needs to break in some.
Optimum Performance
Gold Sponsor
Titusville, Florida
www.facebook.com
Tommy
'15 GT PP
Have Ford check it, because then there is a history in the system of the issue.
Have them bleed the clutch and make sure you are fully pressing the clutch during shifts.
Ford puts an additive (XL-18) in the factory fill to help the syncro's break in. You could see if they will change the fluid out and install the additive (maybe yours did not get additive or the proper ratio) The factory fluid is not that great. If it is not resolved after 1000 more miles change the fluid, to BG Syncro Shift II.
Barton and MGW are proven shifters that do make a huge difference.
RubyRedVert
Zeeland,MI
I had the Ford technician drive the car this morning. It made the grind each time he shifted into 4th. The technician commented that there is an issue that needs to be resolved. They are going to call me back with a recommendation for the repair.
Kong76
Turlock, Ca
2016 Ingot Silver GT
I have a similiar issue with third, 1935 miles. Dealer said nothing out of the ordinary so ill be glued to the results here.
RubyRedVert
Zeeland,MI
The car is going back into Ford this Friday. Sounds like they are going to try the fluid flush and check the shifter linkage first. If that doesn't fix it, I've instructed them to keep the car until it shifts properly. I'll update the tread with the details of the repairs.
RubyRedVert
Zeeland,MI
The transmission oil was found to be full of metal. This must have been from driving it with the 3-4 grind. The car had exactly 1212 miles when I took it in. Anyhow the Ford dealer is doing a complete rebuilt of the transmission under warranty.
z06psi
Evans, GA.
Andrew
The pot stirrer
Barton, heavy shift knob, and Royal Purple made massive difference. Then the RXT twin made another huge difference.
