AMP-D
- Apr 22, 2015
- Texas
- Website
- www.ampdistributing.com
- Mike
- 2015 Gt
100% correct.I don't see how that is counter to what AMP-D has stated. The bearings might have been the root cause of the issue, but not the source of the actual whine noise. Like he said, bad bearings will lead to poor mesh of the gearing. The gearing makes the noise because the bearing allows it to. In our products, the gearing can move around a little bit and the actual mesh pattern can sometimes change, but because differential gearing turns so slow (just a few RPM), it isn't sensitive to this sort of noise. We can get away way with tooth profiles that would scare a transmission guy, which makes the hobbing faster. But transmission gearing spin at much higher speeds and are very sensitive to tooth profile and mesh condition, just like a rear axle ring & pinion is very sensitive to the same things. If it is set up wrong - or moves under load due to bearing issues - it will whine. But the bearing itself isn't generating the noise.
