MRR M350 square + spacers?
ghostnote
PR
Mustang GT 2015
Anyone have the m350's in a 10" square setup with spacers?
What size spacer did you use? Will the nuts reach a decent thread depth?
I'm looking for a bit more flushness. I'm at stock ride height for now.
Paul@PKAUTODESIGN
The Wheel guy
Los Angeles, California
WWW.PKAutoDesign.com
Paul A.
2016 Shelby GT350 Tech Pack #G5531 Avalanche Grey
The M350 is a 19x10 ET 35 if you want to use factory studs widest is a 5mm maxing at a 8mm with ET lug nuts to be used. This will ensure the safest amount of turns for you.
ghostnote
PR
Mustang GT 2015
Paul, i just learned that there are two ttpes of spacers. The thinner ones use extendes studs and the others can ve bolted on. It seems that extended studs are really expensive from what ive seen, so it may make sense to use a thicker bolt on spacer.
Would 20mm look good? What is a good brand for hubcentric spacers?
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Have you seen how flush the 19x10 ET 35 like the M350 are already?? Going any wider in the rear and they'll be poking out noticeably. These are not like the factory wheels all sunk into the wheel wells.
In the front you could run some small spacers, but most people are happy with the fit w/o spacers.
ghostnote
PR
Mustang GT 2015
I have m350's already. They are not flush...
NightmareMoon
Yeah they're +40, so slightly tucked in the back. A 5mm spacer is cheap and should make them flush in the back (40-5mm spacer = 35, which is pretty flush).
If you want exactly a 15mm spacer in the front, you're looking at longer studs.
