MFP Whipple Crank Supports IN STOCK! - Lethal Performance
JakeLethal
Wellington, FL
Jake
2022 F-150 RCSB 5.0
MFP Crank Support Kits for Whipple’d Coyote Mustang’s are BACK IN STOCK!
With both 6 Rib and 10 Rib Kits available, both fitting Gen. 3-5 Whipple Supercharger Systems on any 2011-2022 Ford Mustang GT, these are the perfect solution to protect your crank snout from snapping under the most extreme conditions.
The crank support system on the Coyotes are a weak link when installing an aftermarket supercharger, especially the larger Whipple Superchargers units. The added force on the belt & pulley system has been known to flex or snap the 5.0L Coyote crankshafts causing catastrophic damage.
These crank support systems help to minimize any flex or movement in the front of the crank to help prevent breakage.
Made from Billet Aluminum.
Billet 316 Steel main bearing.
For more info, check out our full write-up HERE!
Get yours here while they last!
Of course, if you have any questions or want to get something on order, feel free to reach out to any one of us here at Lethal Performance!
