Lethal Performance presents: The Lethal Lowdown | Episode 1
Stephen@lethal
2020 Mustang Gt500
We're bringing you a new type of video for us here at Lethal Performance. We'll be keeping track of industry news, product releases, customer features & more and bringing them to you all wrapped up (with a nice little bow!) in a segment we call the Lethal Lowdown. Check out the video below & scroll down for info, links & more about the topics discussed.
In this episode (click each one to jump to the info):
2020 C8 Corvette longtubes from LTH
Long Tube Headers (LTH) have released the details on their new long tube headers for the 2020 Chevrolet C8 Corvette and they are a thing of beauty! These headers are made from T304 Stainless Steel with their Titan™ finish. They are available with either 1 7/8" or 2" primaries for multiple build types! And for the connections? 3 options: off-road, high flow cats or retain the OEM cats. The high flow cats sound awesome and BONUS are their new ECO f, eco-friendly cats.
CLICK HERE for the 1 7/8" primaries
CLICK HERE for the 2" primaries
Whipple 2020 GT500 Intercooler & Intercooler Block
Sharing the same technology that helps push the Whipple Superchargers to win race after race, the all new, super high density GT500 intercooler core is now available to help keep your 2020 GT500’s manifold air temps under control (even with increased airflow, where the stock system begins to quickly run out of capacity). The new core features 33% larger inlet and outlet water passages, for significantly increased flow capacity over stock or other aftermarket intercooler cores. The super high density, offset fin design allows increased cooling capacity in the same area vs the stock, standard density fin. With the billet flange, the SHD core was able to utilize 10% more surface area for increased cooling capacity. Put all this together and you have a more efficient intercooler that fits with the stock supercharger system, while being upgradeable with our intercooler block. The intercooler block opens up the passages for larger diameter fittings & a tapered design, allowing a higher, smoother flow into the intercooler. The block/manifold will work with either your factory intercooler OR paired with the Whipple intercooler for the ultimate cooling setup.
CLICK HERE to check out the 2020 Shelby GT500 Intercooler (w/ optional block add-on)
CLICK HERE to check out the 2020 Shelby GT500 Intercooler Block
Palm Beach Dyno did some E85 testing on Ken’s 2020 Shelby GT500
Ken Bjonnes of Palm Beach Dyno has tuned a few 2020 Shelby GT500s with smaller pulleys but wanted to see what the car could do on the STOCK supercharger pulley with some basic mods and E85. Well, folks, it's IMPRESSIVE! Bone stock, the car made 668rwhp. With some mods, some corn & some tuning the car put down 858rwhp! That's a 190hp increase with just a few parts... Technology is an awesome thing.
Here are the mods on the car:
  • JLT intake
  • Lethal Performance Race Pipes
  • Lethal Performance Resonator Delete
  • D1300x injectors
  • divisionX GT500 fuel rails
  • E85
Intake, exhaust, injectors for the E85 and a set of fuel rails (we'll release a video shortly on WHY you'll want these on your GT500). That's it.
We offer these parts in custom Power Packages or individually to build a package of your own.
CLICK HERE to check out the JLT Intake
CLICK HERE to check out the Palm Beach Dyno nGauge w/ custom tuning
CLICK HERE to check out the Power Packages available for the 2020 Shelby GT500
Crank Support kits for multiple applications
Mustang Hub magazine recently posted an image of Procharger's new Crank Support kit for the Gen 2 5.0L guys. Crank snapping has been a long standing issue, becoming more prevalent as we make more & more power with these cars and relying on the crank to drive the blowers. Procharger having the option to add these to kits is outstanding. We'll have them up on the site as soon as possible for you.
MFP Australia Crank Support Kits for Whipple Superchargers
If you run a Whipple Supercharger on your 2011-up Mustang GT and you're pushing any kind of higher boost, you may want to look into the MFP Crank Support kit. We did a video and write-up covering the how & why on it, CLICK HERE to check it out. Since that video, MFP has released a new 6-rib option for the kit so you don't need to upgrade to the 10-rib setup to run it. We have these on the way to us right now and should be in our warehouse shortly to ship.
CLICK HERE to check out the MFP Crank Support Kit
J2 Fabrication Cobra Crank Support Kit
Attention 03-04 Cobra guys you are NOT FORGOTTEN! Our man Justin Wheeler from J2 Fabrication has finished his 03-04 Cobra Crank Support Kit for the #cobros and it's a piece of art.
Check out the features:
  • 21mm Hex on tip of mandrel to allow CW/CCW rotation of engine
  • Support legs indexed into main plate to eliminate any chance of plate shifting
  • Multi-axis support gussets that lock bottom stand offs into the pan rails to ensure the strongest and safest method of locating the bearing plate without any chance of shifting or slipping
  • Integrated crank ring idler, eliminating the need for other AUX systems
  • 1/2" of diagonal pulley travel to make precise tensioner adjustments or aid in belt installation
  • Supports both 8 and 10 rib IW - Metco hub configurations up to 4lb Rings
  • Clears stock fan and all accessories
CLICK HERE to check out the J2 Fabrication Cobra Crank Support Kit
Borla on SALE through May 31!
Wanting some new exhaust for your ride? We have most of Borla Performance Exhaust systems marked down on the site right now through May 31st. Axlebacks, catbacks & more are up to $250 OFF! There's no code needed, the pricing is already discounted. Don't delay, prices go back up June 1!
SAVE on your favorite brands just by logging in!
Are you familiar with our Lethal Loyalty program? If not, let me break it down for ya! Our Loyalty program has two parts: points & pricing.
First, you'll earn points for every $1 you spend here at Lethal Performance. As you add up those points, they can be cashed in on a later purchase for $$ off. Spend money, make money.
Second, and this is the best part, as a Loyal Lethal member you'll have access to special pricing on brands like Corsa, Procharger, Exedy, MBRP, Kooks, Exedy & more! To access your special pricing all you have to do is LOG IN. #lethalloyalty
Corsa headers IN STOCK
We are always adding to our inventory here at the warehouse and right now we have a bunch of Corsa Performance headers on the shelf ready to ship for you! Whether you have a 2011+ GT500, GT350 or a 2015+ Mustang GT we can get Corsa's stainless steel longtube systems out the door to you the same day you order.
CLICK HERE for the 2011-2014 Shelby GT500 Longtubes from Corsa Performance (A Lethal Performance EXCLUSIVE!)
CLICK HERE for the 2015-2020 Shelby GT350 Longtubes from Corsa Performance (A Lethal Performance EXCLUSIVE!)
CLICK HERE for the 2015-2017 Mustang GT Longtubes from Corsa Performance
CLICK HERE for the 2018-2020 Mustang GT Longtubes from Corsa Performance
BMR Suspension IN STOCK
BMR Suspension is one of our most popular lines (and for good reason!). We have a bunch of their suspension pieces on the shelf to ship same day, including control arms, lowerings springs & even K-members! Interested in running BMR Suspension but not sure where to start?? We have worked with Kelly from BMR Suspension to create awesome packages ranging from street (Biscuits & Gravy) to street/strip (Bread & Butter) to strip level (Streak & Potatoes) for the S197 and S550 Mustangs. CLICK HERE to check out Kelly's Korner going over the WHYs of each piece (Kelly's Korner 2 coming soon!!) & check the kits out below.
S197 Suspension Kits
CLICK HERE for the Biscuits & Gravy Suspension Package for your S197
CLICK HERE for the Bread & Butter Suspension Package for your S197
CLICK HERE for the Steak & Potatoes Suspension Package for your S197
S550 Suspension Kits
CLICK HERE for the Biscuits & Gravy Suspension Package for your S550
CLICK HERE for the Bread & Butter Suspension Package for your S550
CLICK HERE for the Steak & Potatoes Suspension Package for your S550
Lethal Performance Street Warrior Clutch & Lightened Steel Flywheel
We love bringing you NEW stuff and we are super excited about our latest Lethal Performance products: our Street Warrior clutch kit and our Lightened Steel Flywheel.
Our Street Warrior clutch kit is rated to 700hp and is a GREAT option for the 2011-2017 Mustang GT guys running blowers at stock or mild boost levels. For more info on the clutch, CLICK HERE to check out our Tech Tips video.
Our new Lethal Performance lightened steel flywheel is an 8-bolt design & is a perfect match for most aftermarket clutch kits, including our Street Warrior clutch kit and the McLeod Racing RST and RXT setups.
We have these flywheels and clutches IN STOCK and ready to ship.
CLICK HERE to check out our 2011-2017 Mustang GT Street Warrior Clutch Kit (available with or without flywheel)
CLICK HERE to check out the Lethal Performance LP-854 Lightened Steel Flywheel
New #teamlethal gear
You asked for them and we're delivering! We have not 1 but TWO new Lethal gear products!
First up, we have a new #teamlethal buff (aka face mask, gaiter, etc). Normally these are great for fishing, off-roading, etc. but with the current crazy times they are also good for daily activities when leaving the house & avoiding 'Rona.
Next up, our Limited Edition COVID-19 shirt featuring our beloved skull logo wearing a mask. A sign of the times, for sure!
These are both up for pre-order & will be shipping soon. They are sure to sell fast, so get yours on order now!
CLICK HERE for the #teamlethal face mask
That's it for this episode of Lethal Lowdown. Stay tuned for future episodes here at #teamlethal.​
