Hub/Spigot dimensions
Myweepony
Aberdeenshire
Phil
Mustang GT Auto
Hi Guys
I've done a few searches but just getting more confused. I don't have my own car yet otherwise I'd measure them myself. Apparently my car's getting built on Monday, wooohoooooo.:cheers:
Has anyone measured the hub/spigot diameter, the length of the spigot including the hub nut cover (not including the dome) and the length of the studs from the hub face? With the brake disc still in place.
I've seen a few numbers within a couple of tenths (mm) but it must be the engineer in me that wants proper numbers, not roundabout numbers.
Thanks in advance. Cheers.
Myweepony
Aberdeenshire
Phil
Mustang GT Auto
Bump for weekend crew.
Anyone help please?
Ford say hub is 70.3mm diam. Is it? What sort of tolerance is on that?
Wheel is 65mm centre bore. What bore is required for good hubcentric fit? Need to locate on hub not studs.
If I can only machine larger bore for a depth of 10mm would that be enough?
Thanks
sigintel
Ray
2018 GT
Where u find Ford say 70.3? Link?
That sounds off.
I get motorsport grade spacers cut 70.48mm ID for hub centric with 12-13mm depth in the spacer for the OE Hub Lip.
Hubs have roughly 70.45 - 70.47 mm at 12.5 mm lip height(including chamfer and with stock thickness brake rotor).
Not book spec, actual measurements from 5 hubs.
Hope that helps.
Updated dims.
Myweepony
Aberdeenshire
Phil
Mustang GT Auto
That sounds off.
I get motorsport grade spacers cut 70.45-70.48mm ID for hub centric with 12-13mm depth in the spacer for the OE Hub Lip.
Hubs have roughly 70.42 +/-0.02 at 11.76mm lip height(including chamfer).
Hope that helps.
PM if you need spacer CAD drawing.
https://www.wheel-size.com/size/ford/mustang/2015/
http://www.wheelfitment.eu/car/Ford/Mustang (2005 - ).html
OK, so not Ford, but there's a number of sites out there that quote these figures.
There's also numerous threads on other forums, including one on here that you contributed to, that quote various sizes that they claim to have measured. I've seen ranges from 70.3 to 70.8mm. Hence the confusion.
Thanks for the numbers you've posted. I will PM for CAD drawing.
