Help! Need a good place to do an alignment
Bob_Whit
Menomonee Falls, Wisconsin
2016 GT Premium PP
I'm in the Milwaukee area & had Steeda springs put on. The place that did the springs can't do the bushing reclock. Ford dealers won't do it, even one who was a Steeda seller.
I also think that when the shop did the alignment, they didn't get it right - the cars is as squirrely as heck.
Does anyone know of a good alignment shop in the area that could do it?
BagNasty15
847- Zion,IL
2015 Mustang GT (GT350 Conversion)Black
What is a bushing reclock?
Bob_Whit
2016 GT Premium PP
Basically, when your car is made, all the bushings are torqued with it sitting on all four wheels. When you lower , you should sit all 4 wheels flat (or drive-on lift) & loosen the bushings to let them relax. Then retorque to factory specs for the new ride height.
I've lowered my car & it now sits 1" lower but all the bushing were torqued with it 1" higher. It puts a bit more twist in the rubber, kind of like wrinkle slicks. It makes the handling a bit vague & kind of floaty. I have read that some bushings are designed to capture the rubber & fail eventually if they are not "relaxed" to the new ride height.
There are a bunch of threads in the suspension forum regarding this.
KWK GT
Wisconsin
2015 GTPP
You can try Big Bear in Oconomowoc or Frame and Axle in Brookfield. I am going to lower over the winter and will most likely take the car to Frame and Axle.
Did you add caster camber plates? What springs did you go with?
Bob_Whit
2016 GT Premium PP
Hi
Thanks for the response. I didn't add the plates, I used Steeda Progressives. It was aligned by Ford & is in spec, but one side seems really on the edge. I may get plates in the future, car's in storage now.
milwaukeephil
New Berlin, WI
2015 GT Convertible
I'm in New Berlin and have a big shop with a drive-on lift. The lift also has a trolley jack so you can get the wheels off the track. You're welcome to come out and futz with it sometime. I've got tools and beer!
Edit: this offer is also open to any forum members who may need to get their car on a lift and a clean place to work. I love wrenching and shooting the shit.
Bob_Whit
2016 GT Premium PP
Welcome to M6G
Great looking shop, home or work?
