Does the Mustang ECU reprogram itself if you run higher octane? If not it will actually run worse but I wouldn't think bad enough to throw a code.Gas will not trigger a cel, the car will perform better with the higher octane. Take it by an advance/auto zone and have them read it or wait until tomorrow and call your local dealer.
The ecoboost does. 87 vs. 93, a noticeable different in HP/TQ. Reported by Ford as well.Does the Mustang ECU reprogram itself if you run higher octane? If not it will actually run worse but I wouldn't think bad enough to throw a code.
Higher octane fuel is only better to run if your engine is tuned (advanced timing) to run it.
Nice. Well done Ford. The ECU on my 2012 Camaro SS/RS would detune if you put regular in it but was too dumb to tune back when you put premium in it. You had to pull a fuse to reset the ECU.The ecoboost does. 87 vs. 93, a noticeable different in HP/TQ. Reported by Ford as well.
