Harrop Oil Cooler and Whipple Large Heat Exchanger
turbofiveoh
EZ Street
Mustang
Does anyone know if these can be installed together? I’m in the middle of installing the oil cooler kit and the bracket are too short. Before I call harrop I’m curious if anyone has done the install. If not, it’ll be custom brackets.
Thanks.
turbofiveoh
turbofiveoh
EZ Street
Mustang
In case anybody is doing this in the future, the forward brackets need to be spaced down 1". This gives ~.250" clearance between the lowest arc of the Whipple heat exchanger when it moves on the mounts and the fins of the oil cooler radiator. The bottom of the oil cooler radiator is still slightly higher than the bottom of the frame rails. Hopefully nothing hits in front when the close out panel goes on.
