Going to track soon for the first time
Bill88stang
2016 deep impact blue premium gt 6 speed manual
For those out there with the stock 235 on 18's what have you done to get he best launch on the stock street tires? I'm manual I'd assume even trying to use the launch control at the lowest setting of 3k would be useless and just produce wheel spin? Car is all stock minutes the h pipe resonator delete
bluebeastsrt
Oh boy
New Jersey
BigD
Ruby red 2019 GT Premium.
Try leaving around 1500 rpms and riding out the clutch as you feed in throttle progressively.
Bill88stang
Should I keep the stock pressures up or lower a bit? Also running in track mode just disables traction control but keeps the advance trac on right?
Bill88stang
What is a good shift point also?
wildcatgoal
@sirboom_photography
TBD
This.
And if your back end comes loose and kicks to the side... LET OFF and get it straight. Give up the run -- you are not a professional drifter. Don't end up in a wall... its expensive.
bluebeastsrt
Oh boy
New Jersey
BigD
It wont hurt to lower the tire pressure down to about 25psi. Yes track mode as described. But you'll want to turn everything off for drag racing. Hold the traction control toggle up for about 7 second til you see it turned off on the dash.
wildcatgoal
TBD
I do 28 psi at a drag strip... of course I'm hopeless at a drag strip... so... haha.
Bill88stang
What's the best rpm to shift at?
