Cathul
Yes, it's expensive, but i would at least the the HRN-AR-FO3 harness from idatalink. It has all the plugs to connect your aftermarket wiring to the stock speaker wiring and the signal lines that you can use to connect RCAs to. You (or your installer) just have to modify the harness to get the signal wires from the idatalink connector.
Tweeters you always have to rewire as the stock tweeters don't have a dedicated wiring, but are connected to the midrange wiring.
