Gen III camshaft specs
Performance nut
TX
2018 Mustang GT A10
Does anyone know the camshaft specifications for the Gen III. Only thing I could find is that they are 14mm lift. I couldn't find duration or lobe separation specs.
Performance nut
Performance nut
TX
2018 Mustang GT A10
The top line in the cam table shows "stock" cam spec's ... View attachment 445353 View attachment 445353
Totally missed that. Thank you.
@LethalPerformance @LethalBlake I think the Gen III stock cam specs on your website may be wrong, at least for lift. I found this document from Ford that shows the differences between all the Coyote generations and it specifies 14mm lift for intake and exhaust for Gen III. Though it doesn't reference duration or lobe separation. Do you mind sharing where you got the OEM camshaft specs?
