• Welcome to Mustang7G!
    If you're joining us from Mustang6G, then you may already have an account here!
    As long as you were registered on Mustang6G as of March 10, 2021 or earlier, then you can simply login here with the same username and password!
JM150
Buffalo
2023 F-150 5.0L V8
The standard GT engine has a few more updates than meets the eye. The connecting rods are updated as it now shares the part # with the 21+ F-150 engine. You can see the flange is a tad thinner, which is likely resulting in better throttle response/ less windage losses. For N/A lightest and strongest possible is the goal, heavy rods sap up power. ML3Z-6200-A is the 2021+ F-150 rod that the GT is now using 2024+. The older rod is CR3Z-6200-B. The 14th gen F-150 version of the engine also got a 87 mm throttle body like the Mach 1 and Billet S550, ditching the 80 mm after 2020. It’s funny, the S550 Mustang 5.0 (besides Mach 1) was actually running a smaller throttle body than the pickup truck version since 2021.
S650 Mustang Gen 4 Coyote 5.0L V8 Specs & Photos (S650 Mustang) IMG_6422
Rickety
Lexington, KY
93 Cobra/Voodoo Swap
JM150....
I can't tell from the pics...But, I'm assuming the ML3Zs...Do not have the big end machined for the bearing tangs...??
Thanks
YamenGT650
Dubai, UAE
Mustang GT 2024 PP
I found this on FP instagram page today.
Interesting to see the engine control type difference.
S650 Mustang Gen 4 Coyote 5.0L V8 Specs & Photos (S650 Mustang) IMG_4925
