Gearing Equivalents
TheLion
US
Ruby Red 2016 Mustang GT PP 6-MT
Manuals:
3.31 Speed Engine RPM
4.236 ↔ 40.12 MPH 7000
2.538 ↔ 66.96 MPH Tire Height (in.)
1.665 ↔ 102.07 MPH 27
1.238 ↔ 137.27 MPH
1.000 ↔ 169.94 MPH
0.704 ↔ 241.39 MPH
3.55 Speed Engine RPM
4.236 ↔ 37.41 MPH 7000
2.538 ↔ 62.43 MPH Tire Height (in.)
1.665 ↔ 95.17 MPH 27
1.238 ↔ 127.99 MPH
1.000 ↔ 158.45 MPH
0.704 ↔ 225.07 MPH
3.73 Speed Engine RPM
4.236 ↔ 35.60 MPH 7000
2.538 ↔ 59.42 MPH Tire Height (in.)
1.665 ↔ 90.57 MPH 27
1.238 ↔ 121.81 MPH
1.000 ↔ 150.80 MPH
0.704 ↔ 214.21 MPH
TheLion
TheLion
US
Autos (assuming 10% converter slip which is typical):
Rear Axel Ratio 3.15 Speed Engine RPM
1st Gear Ratio 4.170 ↔ 38.54 MPH 7000
2nd Gear Ratio 2.340 ↔ 68.68 MPH Tire Height (in.)
3rd Gear Ratio 1.520 ↔ 105.73 MPH 27
4th Gear Ratio 1.140 ↔ 140.98 MPH
5th Gear Ratio 0.870 ↔ 184.73 MPH
6th Gear Ratio 0.690 ↔ 232.92 MPH
Rear Axel Ratio 3.55 Speed Engine RPM
1st Gear Ratio 4.170 ↔ 34.20 MPH 7000
2nd Gear Ratio 2.340 ↔ 60.94 MPH Tire Height (in.)
3rd Gear Ratio 1.520 ↔ 93.82 MPH 27
4th Gear Ratio 1.140 ↔ 125.09 MPH
5th Gear Ratio 0.870 ↔ 163.91 MPH
6th Gear Ratio 0.690 ↔ 206.67 MPH
Rear Axel Ratio 3.73 Speed Engine RPM
1st Gear Ratio 4.170 ↔ 32.55 MPH 7000
2nd Gear Ratio 2.340 ↔ 58.00 MPH Tire Height (in.)
3rd Gear Ratio 1.520 ↔ 89.29 MPH 27
4th Gear Ratio 1.140 ↔ 119.06 MPH
5th Gear Ratio 0.870 ↔ 156.00 MPH
6th Gear Ratio 0.690 ↔ 196.70 MPH
3.55 Auto is roughly equivalent (just a tad lower geared) to a 3.73 Manual. 3.73 Auto would probably be too short gearing. In 4th a 3.55 can trap up to 125, in 4th a manual can trap up to 122, assuming a 7k cut off for both.
I know people have mulled putting in a 3.73 in an auto, but I think a 3.55 is probably more optimal. 3.73's work well though in the manual as your pegged to each gear, there's no converter slip (also slip changes, at lower RPM your have more slip = torque multiplier, some converters can multiply up to 2:1 before stall, but I"m not sure what the 6R80's spec is).
hungryhippos
Seattle, WA
2016 Mustang Ecoboost
This crossed my mind after seeing the 3.73 EB conversion thread, thanks for sharing your insight!
TheLion
TheLion
US
When the numbers are worked out, I think what Ford was trying to achieve is utilizing the low end torque the EB makes more often. Given how the factory PCM software as a very low torque goal in the upper rpm range (combined with the IC deficiency), there's really no reason to run a bone stock EB in that range. Taller gearing makes sense and w 3.73's were not considered a factory option even though manual tuned EB's with a good FMIC do very well with that gearing and it's roughly equivalent to the auto with a 3.55.
The low end torque is still useful with 3.73's even if it's not utilized as much (especially for DD), it's useful for getting off the line or getting the car going after a shift (when the RPM drops into the 4k range) in the first two gears. Here's a shift point chart for MT-82 and 3.73 I created based on LMS dyno (to get an approximation of where I should shift to keep the most area under the curve for each gear change):
Optimal Shift Points End RPM Start RPM End Power Start Power
1st - 2nd 7000 4200 290 HP 275 HP
2nd - 3rd 7000 4600 290 HP 290 HP
3rd - 4th 6350 4725 300 HP 305 HP
Obviously this is not exact and would need to be tested, but based on the RPM drop (less the higher the next gear obviously as the ratios become closer and closer), shift points are different at different RPM's.
First two gears it makes sense to rev it out to keep the most area under the curve, but 3-4 makes more sense to shift a bit earlier to keep the RPM centered around the power curve.
