FS: Gorilla Black Lugnut Kit + Thin Wall Socket Adapter NEW!! 15-18
emericA243
pa
2016 Ecobeast PP
new, never used. $30 shipped
Black Gorilla Small Diameter Lug Nut Kit for all 2015, 2016, 2017 and 2018 Mustangs.
Install your aftermarket or factory wheels on your 2015-2018 Mustang with a set of Gorilla's high quality small diameter closed end lug nuts. For 2015, Ford decided to change the wheels studs from the typical 1/2”-20 Thread pitch to 14mm-1.50 pitch. With the 2015-2017 Mustang now being a world-car and producing more power than ever before, Ford felt the need to beef-up the OEM wheel studs for an added sense of security. Gorilla has stepped up to the plate and created these lug nuts in black and they will not only look great, but will also function perfectly.
Gorilla Lug Nuts: Features and Benefits
What makes Gorilla black lug nuts so special? They’re manufactured using high-strength steel that stands up to routine wear and tear. Gorilla’s black lug nuts are also specifically made to fit the 2015-2018 Mustang’s specifications so you can easily replace stock lug nuts on aftermarket wheels.
In addition, these Mustang lug nuts are coated to prevent rust and wear over time. That means you can swap them out for the factory-original lug nuts to securely hold your wheels without worrying about them showing rust or degradation. Plus, because of their dark coloring, they’ll hardly even show dust or dirt that you kick up when you’re cruisin’ down the open road.
To make sure these Gorilla lug nuts are the best options for your ‘Stang, check out these specifications.
Specifications:
- One Thin Wall 13/16” x 3/4” Chrome Vanadium Steel Adapter socket
- 20 Lug Nuts with 14mm-1.50 Threads
- Closed End Design Will Prevent Rusting
- Direct Fit for all 2015-2018 Mustangs
- Compatible With OEM or Aftermarket Wheels
The lug nut's closed-end design prevents rusting problems so the lug nuts will always thread smoothly and look great. The external pattern design produces better torque and prevents breakage. Gorilla lug nuts also provide more seating surface than traditional lug nuts. This is achieved from the 60 degree conical seat which is standard with most Mustang wheels. Additionally, each Gorilla lug nut is stamped with the thread size for easy identification and to prevent confusion amongst existing lug nuts.
*These Lug Nuts from Gorilla will ONLY fit 2015-2018 Mustangs
Most aftermarket wheels are made with smaller lug nut openings which can cause a tight fit for the factory lug nuts. This increases the chances of damaging the wheels with a socket or lug nut key. Gorilla offers this lug nut kit with small diameter acorn style lug nuts that use a specific thin-walled socket that minimizes the potential to damage the wheels. These Lug nuts are also heat-treated for superior strength and finished in Black to accent your Mustang's exterior theme.
Gorilla’s black lug nuts are ideal for aftermarket wheels on 2015-2018 Mustangs, but they can also work with stock wheels. These lug nuts also come with a compatible socket so you can secure them to your ride even if you don’t have a full toolshed at home.
Gorilla manufactures lug nuts specifically for 2015-2018 Mustangs so you can secure your wheels and cruise around town in style. Plus, when you shop at CJ Pony Parts, you can be sure you’re getting the best price on all of our products, including these quality lug nuts! And best of all, if you order your lug nuts before 5 PM EST, we can ship them that same day so you can get your parts as quickly as possible. We’ll even do it for free for most orders.
emericA243
pa
2016 Ecobeast PP
Pending to ChaddyP - will send more pics when i get home from work in about 2 hours
