Sold: FS: Custom Whipple Fan Switch & Harness
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
I made this fan switch assembly to be able to turn off my Whipple fans when needed. I turned them off in the winter, at drive-thru windows or when ever I just wanted quiet.
This is made up of a custom switch that illuminates when fans are on and it is mounted to an OEM dash panel so it's just a direct swap with yours. I made the harness plug and play as well. It will connect to the IMRC turn on lead from your whipple harness and run to the switch. Then it returns to the same spot and connects to the relay with plug and play connectors. The ground was connected on a factory ground stud just above the kick panel fuse panel just after it entered through the passenger side wheel well grommet.
I cut the harness just outside the grommet as to not have to take the ends off either end so you will just have to either solder or butt connect the three wires back together and your good to go.
I have pictures of how I ran it and how I cut it and I will forward to who ever buys this.
$50 shipped, you cover the PayPal fee
