Front blinker out?
articrandom
Midwest
16 Mustang
So a couple days ago I noticed my blinker noise going twice as fast when turning the right side blinker.
I came out and since it was still sunny out the front blinker lights were not light up like they are when your lights turn out automatically after it gets dark.
Long story short, I assumed it was the blinker but tonight as I was in the parking lot, I saw that the front turn signals are light up (both sides) but when you turn the right blinker on, it doesn't blink it just stay light up.
Am I missing something? Is the bulb defective? wiring issue?
I can upload a video if needed...
wanted33
Down South in Dixie
Jim
2018 GT Convertible, 2006 GT Coupe
I know you don't want to, but it sounds like a visit to the dealer is in order. It could be a number of things, i.e. wire loose, bad bulb, etc. Good luck.
I'm fairly sure the "blinker fluid" ain't low as it's a new car. :) JK
zxd9
GA
2016 GT Premium PP
Seriously, double check the blinker fluid. Mine had a small pin-hole in it when I first got it. Dealer fixed it right up. My dealer offered to drain the fluid out of the other blinker and said I could change the color if I wanted but I just stayed with factory default stuff.
  • Like
Reactions: pjk
wanted33
Down South in Dixie
Jim
:lol: I just knew it wouldn't take long. :D
articrandom
Midwest
16 Mustang
Ha ha ha you are hilarious man
Jetboy
Appleton WI
2015 GT Prem / 1999 Yellow GT Convt.
Have to reprogram one of the body control the modules, Happens when the battery voltage gets low. To the dealership you go.
CVCashmere
South Jersey
Carl
15 GT Vert w/Steeda lower brace, PP sways & susp
Geez...it sounds like a double filament bulb? My Fusion did something similar. It blinked twice as fast. Replaced the bulb and the problem went away.
CVCAshmere
SleepyPony
Bay Area
2016 Ecoboost
Same thing just happened to my front passenger side turn signal. The drivers side is completely fine. Kind of annoyed because my AC went out for the second time, this happened, and now my clutch pedal has this annoying feeling. My clutch pedal feels like there’s an imaginary piece of gum on it and the pedal feels like it pops/jerks when completely letting off the clutch.
