FORscan help
v8hgt
Cheshire, UK
Nick
Race Red GT PP Coupe
Hi all
I want to disable my DRL's and I think this is possible using FORscan software and an OBD device such as the obdlink mx.
Before I shell out £100 for the obdlink, Does anyone know if tune devices such as nguage and sctx4 allow you to do the same thing or are two separate devices required? Alternatively can these things be requested in the custom tune from Lund ?
Manders Mustang
The Boss
Birmingham - United Kingdom
2016 Race Red Ecoboost
Hi all
I know my Cobb doesn't do this, however I know @Accull2000 has used forscan to remove his DRL link :thumbsup:
MakStang
Greece
www.cellentis.uk
Makis
A 2017 miraculous little beast
One of the following links will probably help you do what you want:
http://www.mustang6g.com/forums/showpost.php?p=1823666&postcount=1552
http://www.mustang6g.com/forums/showpost.php?p=1824788&postcount=1559
Also I found on eBay this USB adapter that works perfectly with FORSCAN, as it can read and write HS and MS-CAN modules, without the need of an expensive Bluetooth or WiFi adapter:
ELM327 USB modified for Ford ELMconfig FTDI chip HSCAN / MSCAN Forscan OBD2
http://www.ebay.co.uk/itm/ELM327-US...e=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649
It's of great quality and very easy to use. You can also find the exact same adapter shipped from the UK for a lot cheaper if you search on eBay.co.uk.
TaraFirma
Wait.....Wut?
88 GT, 17 GT350
Hi all
Ngauge/SCT devices will not do what you want. You need a OBDLink device that can communicate and write to the CAN BUS modules in the car, and FORScan
acull2000
UK
iPace
Yup, you need an OBD connector. If you can handle a little bit of wiring/soldering, you can buy a £15 ELM connector from ebay and wire it to access HS and MS CAN.
Then download FORscan and get the license sorted.
Once you're set up you can change the DRL configuration settings in the body control module.
Alternatively, just pull the harness off the back of the bulbs - this will mean they will work (for MOTs and such) when you plug them back in.
:D
kapiteinlangzaam
Netherlands
5.0 GT Coupe 6MT PP1
http://r.ebay.com/RvUL6k
That adaptor works a treat.
Used it to cancel the double horn toot last week.
Money well spent :)
Manders Mustang
The Boss
Money well spent :)
[MENTION=8914]Big_G[/MENTION] one for you mate know u love that horn.
wuzie123
Ellon
Doug
do you have an updated link as this one is no longer linked to the item....
Thanks Doug
MakStang
Greece
www.cellentis.uk
Makis
