GTFORMULA
I'm in the middle on a project and wanted to share what I found since in my gooe searches it might pop up.
S550 alxes and 2020 GT500 axles are not the same and can't swap. The end on the wheel bearing side is different diameter and the axle length is also alittle off.
So to swap over you'll need the gt500 spindles and bearings with the alxes.
I didn't bother to take detailed measurements but it was widely different spline diameter and nut sizes also.
The diff size is identical and can fit in the gt500 housing.
