TheLion
I'd be in for one as long as they take pay-pal (I've had issues in the past with online CC transactions and fraud) or if it's a direct purchase from them via phone.
Under what reservoir? It routes to the ducting on the front grille like the factory airbox. I'm not sure what you're talking about.it also has to go under the reservoir, does the whole thing angle down or does it bend? and is it gonna have a connection that steps down or does the tube stepdown?
It utilizes the factory turbo inlet pipe (TIP). Basically speaking, you're replacing the airboxs between the cars.Probably almost identical to the pipe on the roush.
http://www.americanmuscle.com/roush-cai-2015eco.html
They do take Paypal. If you're seriously interested, shoot Steve an email and let him know that you want one. For what it's worth, Tasca would be one of the last vendors that I'd be worried about defrauding me or poor service.I'd be in for one as long as they take pay-pal (I've had issues in the past with online CC transactions and fraud) or if it's a direct purchase from them via phone.
We'll talk whenever I get it in. If it wasn't a Ford setup, I wouldn't even bother, but I'm just curious as to whether it's as good or better than the factory box with the smaller filter. I can't imagine they'd design a poorer performing product and put it on their holy grail Mustang, but there's only one way to know though, lol. You should try to source (borrow) an Airaid too and see how it'd do being a closed box design.Justin, send me yours first I'll put it on the dyno on my setup and compare stock, 3.5" Tube w/ 9" filter, then this thing.
I mean, Roush made an intake... lol.Under what reservoir? It routes to the ducting on the front grille like the factory airbox. I'm not sure what you're talking about.
Are you criticizing the Roush only or making the inference that the Ford Racing filter is on the same order?I mean, Roush made an intake... lol.
Also, the surface area on the stock filter is probably equal to the cone filter.
Exactly, the stock setup is not a restriction on this EB, if anything people are going to be paying for sound and looks, that's it. A good overall setup is, drop in filter + airraide tube + velossa tech ram air + cut off resonator and plug cap on the intake box. Good luck allAre you criticizing the Roush only or making the inference that the Ford Racing filter is on the same order?
Do you have any actual data to give us a clue as to what, if any advantages there are? I'm not going to bother upgrading the rather well designed stock filter for 5~10hp...not on car making as much power as the EB does modified.
I think most people aren't trying to set records, so certain modifications matter while others don't or make undesirable compromises.
I wouldn't even worry about the Airaid tube on the stock box. The factory tube has a real nice, smooth, and linear taper to the stock turbo inlet size. I'd go with the Airaid on a larger stock location turbo like the Vargas or Cavalli.Exactly, the stock setup is not a restriction on this EB, if anything people are going to be paying for sound and looks, that's it. A good overall setup is, drop in filter + airraide tube + velossa tech ram air + cut off resonator and plug cap on the intake box. Good luck all
Can you give more info on "plug cap on the intake box"?Exactly, the stock setup is not a restriction on this EB, if anything people are going to be paying for sound and looks, that's it. A good overall setup is, drop in filter + airraide tube + velossa tech ram air + cut off resonator and plug cap on the intake box. Good luck all
Yes, go on to velossa tech site, and click around till you find the s550 section and they sell the cap, u would have to do the cutting on your ownCan you give more info on "plug cap on the intake box"?
Are you referring to removing the weird little noise cancelling box?
TIA
Roger that.Yes, go on to velossa tech site, and click around till you find the s550 section and they sell the cap, u would have to do the cutting on your own
This is actually the set-up I am using, however I have GT grills. I'm not 100% sure if the Ram Air piece from Velossa will work with the stock Ecoboost grill. Feel free to double check me.Exactly, the stock setup is not a restriction on this EB, if anything people are going to be paying for sound and looks, that's it. A good overall setup is, drop in filter + airraide tube + velossa tech ram air + cut off resonator and plug cap on the intake box. Good luck all
No u are correct, it only works with the GT grill, ty for saying. So how do u like the setup?This is actually the set-up I am using, however I have GT grills. I'm not 100% sure if the Ram Air piece from Velossa will work with the stock Ecoboost grill. Feel free to double check me.
