Favour request - GT owners
NornIron91
Northern Ireland
Paul
croyde
SW London.
BMW E36 323
Etis will show the standard dampers until the car has been to the upfitters. Then you'll see the list changed to the UK and Euro upgraded ones.
djone101
Nowhere
None
None
The part number breaks down into three parts.
Prefix - base part number - suffix
The prefix denotes year (F = 2015) model (R3 = Mustang) engineering area (C = Chassis)
Hence why all parts are FR3 something. There is a breakdown of this elsewhere on the net.
The base part number is specific to the part so a 5310 is always a front spring, 5560 is a rear spring and so on.
The suffix usually starts as an AA - this goes to an AB when there is a design revision but the part is still interchangeable.
If it's not interchangeable or it's for a different application it would go to a BA
The Ford Racing part numbers always seem to start with an M and often seem to use the base part number but I don't know how they allocate them other than that.
Hope that helps somewhat.
stiggy
S.Oxfordshire
S550 V8 Manual Fastback, DIB
Thanks Dave - useful info there!
The only reference I can find for the Ford Racing dampers are M-FR3A-M8. The question is, whether these dampers are any different from the UK spec ones (which I expect will have different damping rates to US cars due to our roads and driving style).
May have to broaden the net and see is any US guys have the actual part number?
Cati
U.k. Down sarf
2015 get v8 ucl mag grey & e93 m3 cp
Gibbo
did they explain the difference in the dampers between track and PP spec?
Gibbo205
UK
UK 2015 Mustang & BMW E46 M3
Gibbo
Racing/Track have more rebound, particular in rear, hence why the bounce is cured, but the shorter higher poundage spring also helps.
To eliminate bounce/floatyness the following all help:
- FRPP Dampers & Springs: Biggest improvement in bounce.
- CB005 cradle lockout big improvement in floatyness.
- Differential support bushes, helps a little with everything.
That combo on the rear turns this into a sorted dynamic car, vertical links helps a little with wheel hop but are nowhere near as noticable as the above.
stiggy
S.Oxfordshire
It was the BMR vid for the cradle lockout that did it for me. Wasn't going to touch it until I saw how dramatic the hop/tramp was.
Gibbo205
UK
Yes but it does so much more, it centre's the cradle and solid bushes it, the car is vastly more dynamic with it, no more rubberized feeling in the rear and no NVH, but a little NVH when combined with Steeda diff bushing inserts, but very minimal and only 1000-1200rpm in traffic when pulling off very slow.
