Stephen@lethal
EXCLUSIVE: Lethal Performance Lightened Steel 8-bolt Flywheel
Here at Lethal Performance we strive to bring you high quality performance parts & accessories. We started our own line of parts featuring catted & off-road stainless midpipes for late-model Mustangs which have been extremely popular, but it's time to expand! Introducing the first product in our line of Lethal Performance clutches & flywheels: the Lightened Steel Flywheel.
Weighing in at 19.4lbs, the lightened steel flywheel is the best option for a street/strip application. It is lighter than a standard steel flywheel, reducing parasitic loss, but has enough rotational mass to not let your RPMs drop out of the powerband between shifts. We've run a lightened steel flywheel in just about every manual Lethal project car and for good reason.
Product Features:
Lightened Steel Construction
8 Bolt Pattern
164 - Tooth
0 oz Balance
SFI Certified
Fits 1999-Mid 2001 GT, 1996-2004 Cobra, 2003-2004 Mach 1, 2011-2014 GT, 2012-2013 Boss 302
Steel Construction | Manufactured from steel for extra strength, this Lethal Performance Lightened Steel Flywheel features a ring gear of 164 teeth, an engine balance of 0 oz, and an eight bolt main pattern. Steel flywheels are perfect for street and race applications where off the line acceleration is desired.
SFI Certified | If you're using this flywheel in high performance or racing applications, SFI Certification is critical so you can run your mustang at the track or strip. And it's great for peace of mind even in a daily driver - at higher RPMs, stock cast flywheels have been known to explode.
Application | The Lethal Performance Lightened Steel Flywheel fits the 1999-Mid 2001 GT, 1996-2004 Cobra, 2003-2004 Mach 1, 2011-2014 GT and 2012-2013 Boss 302 Mustangs with an eight bolt main. This is the perfect companion to your new clutch.
Technical Note | The Lethal Performance lightened steel flywheel has an 8 bolt main that is found in the 1999-mid 01 Mustang GT's with production date ending on 06/01, 1996-2004 Mustang Cobra's, 2003-2004 Mach 1's, 2011-2014 GT's and 2012-2013 Boss 302.
CLICK HERE TO PURCHASE A LETHAL PERFORMANCE LIGHTENED STEEL FLYWHEEL!
We have these flywheels IN STOCK and ready to ship.
We also offer the Lightened Steel Flywheel paired with some of our most popular clutches. Check them out below:
Mid 2001-2010 Mustang GT | Bullitt ; 1999-2004 Cobra | 2003-2004 Mach-1 | 10 spline
McLeod RST Twin Disc Clutch Kit (10 spline) + Lethal Performance Lightened Steel Flywheel
SKU: LP-MCL-6912-03-LP854
McLeod RXT Twin Disc Clutch Kit (10 spline) + Lethal Performance Lightened Steel Flywheel
SKU: LP-MCL-6932-03-LP854
1996-2004 Cobra | 1999-mid 2001 Mustang GT | 2007-2009 Shelby GT500 | 26 spline
McLeod RXT Twin Disc Clutch Kit (26 spline) + Lethal Performance Lightened Steel Flywheel
SKU: LP-MCL-6912-07-LP854
SKU: LP-MCL-6932-07-LP854
2011-2017 Mustang GT | 2012-2013 Boss 302 | 23 spline
Lethal Performance Street Warrior Clutch Kit (23 spline) + Lethal Performance Lightened Steel Flywheel
SKU: LP-10111-LP854
McLeod RXT Twin Disc Clutch Kit (23 spline) + Lethal Performance Lightened Steel Flywheel
SKU: LP-MCL-6932-25-LP854
Product Features:
8 Bolt Pattern
164 - Tooth
0 oz Balance
SFI Certified
SKU: LP-10111-LP854
