I hope you guys are tuning for that cutout... Next thing you know you will open it up, go WOT and pop your motor. You are literally reducing almost all of the restrictions when you open it. The turbo will spool that much faster causing overboost and lean conditions, as the computer won't be able to control it... with the heat these engines produce and lack of cooling you are asking for trouble.
IMO I would stay away from cutouts on a turbo car.
Yes, while I doubt it would create a dangerous situation with a modern ecu, keep in mind that all it takes its a quick boost spike, to cause a slightly lean mix that can result in detonation. Especially with these cars and the shitty cooling we have :first:With the much faster/tighter controls of the EB, I can't see where we would run into an overboost situation unless the tune was right on the ragged edge. I would be more worried about heat soaking the stock IC/driviing up the CAT than I would overboost. The ECM will pull power if you exceed the set target....it's going to protect itself from destruction/loose nut behind the wheel...lol.
