BeauxXL1200
- Oct 5, 2014
- Austin, Texas
- Ralph
- 2015 Mustang GT/PP Ruby Red
Anyone running these Eibach 15 mm spacers?
http://www.stage3motorsports.com/ES90-6-15-056-2015-Mustang-15mm-Pro-Spacer-System.html
I'm considering them to poke my front wheels/tires out a bit. 15 mm should give me a little over 9/16" which I think will be about right.
If you are using them, did you have to trim the length of the OEM studs so the OEM studs are flush or below flush with the face of the spacers?
Since we're only talking about 9/16" width for the spacers, I'm assuming the OEM studs are longer than that. And that the OEM studs with the lug nuts need to sit "inside" the holes in the spacers, and therefore the OEM studs need to be trimmed.
A little more info:
The car is lowered on Steeda's progressive springs.
My front wheels are Velgen VMB7s - 9.5" x 20". The tires are Michelin Pilot Super Sports - 275/35/20s.
I checked with Velgen and they're telling me these spacers should work just fine with my set up.
But I'm not too keen on having to trim the length of the OEM studs. I wonder if I went with thicker spacers - say 20 mm - could I avoid having to trim the OEM studs?
Thanks in advance for ya'll's thoughts. :cheers:
A little more info:
