Dtc code p0420 & p0430
Discussion in 'V6 3.7L Engine / Mods: Bolt-ons, Exhaust, Tuning' started by SquillyP, May 26, 2017.
  1. SquillyP
    SquillyP Well-Known Member
    Vehicle(s):
    2015 Race Red Mustang V6
    Feb 8, 2016
    Louisiana
    104
    I got my LT and catted H pipe installed last weekend. They sent the wrong 02 extensions. Never got this code while driving all last week without the extensions. Got the right ones installed last night. Didn't see a code then or this morning. After driving for a bit after work the code popped up. The code says Catalyst system efficiency below threshold. Would that be cause of some bad 02 sensors? Or actual bad cats? (Brand new catted h pipe). Or would the code just be there cause I have different cats now.
  2. whatdoyoufeedit?
    whatdoyoufeedit? Well-Known Member
    Vehicle(s):
    2019 Race Red EB A10 (Formerly 2016 3X Yellow V6 M6), 1996 Mercury Cougar XR7 4.6L A4 (Future Coyote swap candidate)
    Jan 14, 2015
    Fayetteville, NC
    549
    184
    0   0   0
    The main culprit is probably the extensions. There is too much resistance thus making it throw codes. The best thing to do is drill new o2 bungs near the stock locations so that you will not need to rely on extensions (which rarely work right). If I were you I would also send datalogs to my tuner after everything has been installed as fueling will change significantly after removing the cats. That will ensure you're dialed in and safe.
  3. OP
    SquillyP
    Vehicle(s):
    Feb 8, 2016
    Louisiana
    104
    Thanks! I'll look into drilling new holes and will definitely datalog. The LTs are awesome so I hope it's just the extension
  4. whatdoyoufeedit?
    Vehicle(s):
    Jan 14, 2015
    Fayetteville, NC
    549
    184
    0   0   0
    Keep us posted with the results!
Loading...
Share This Page
