Driveshaft shop driveshaft
Phoneman1223
Dale City, VA
Jason
I’m located in Northern VA and been contemplating putting in one piece. However I’m a little apprehensive about increasing NVH. I’ve got dif bushings, Steeda brace, and cradle to frame lockout bushings. Currently I experience some “clunkness” from backlash in differential and cradle bushing on two piece driveshaft. Under load and spirited driving all the noises go away and very happy how the parts work together. At load speeds gets kinda annoying, especially since it’s technically my wife’s daily.
mkcotton
Virginia
2018 Mustang GT PP1
I took it out because I'll be giving this car to my daughter and I wanted take some of the rawness out of the shifting. I have the same set up as you (diff bushing, steeda subframe connector, etc...) and other than the shift into "R" or "D" there are no noises. A two piece draft shaft makes for a smoother shift (a bit tamer), where the hollow DS drive shaft does ring a little going from "P" to "R" or "D". As far as at speed the DS makes no noises.
lmk.
