VooDoo387R
New from The Driveshaft Shop! They have developed a DIRECT FIT rear CV Driveshaft! This new design eliminates the adapter plate at the rear end with a precision ground CV to fit inside the pinion flange just like the factory. This new design sheds weight from adapter plates while increasing power holding ability and drivetrain response. Their Driveshaft will be an athletic upgrade from the factory soft rubber mounted shaft. Now offering solid connections, perfect alignment, and their new CV with chromoly internals / Spicer 1350 U-joint combination to get the power to the ground. Designed to hold over 1000+ horsepower, so even the most extreme engine modifications won't be a problem.
Features:
3.25" diameter carbon fiber construction
Billet aluminum endcaps
300M Chromoly spline plugs
High-speed precision ground CV joint with chromoly internals. Has twice the range of the previous design
Spicer 1350 series solid U-Joint
Forged aluminum U-Joint flange
1000+ hp Rating
Price: $800 OBO shipped in the lower 48 (NEW, NEVER USED OR INSTALLED).
Features:
1000+ hp Rating
