DBW Throttle Blip Module
Status
Not open for further replies.
Longwood Florida
www.xpmotorsports.com
sales
ford
DBW Throttle Blip Modules
BMW-GM-Ford-Dodge-VW
Blip on Downshift
No more heel to toe
Consistent downshifts rev match
Programmable throttle % target
via
USB (PC or APP) or On-board switches
Interface with Brake and Clutch switch circuits
OR Load Cell Shift knob
Throttle Control Description
Connect this module inline with OEM throttle pedal and Brake/Clutch Switch circuits OR a Load Cell Shift knob/linkage.
Upon detection of a downshift event (Brake and Clutch pressed OR Load Cell Shifter Push) the throttle is commanded to a target % to rev match the lower gear.
During the development of our WOT Shift (Ignition Cut) Module on late model Drive-By-Wire (DBW) vehicles, it became clear we needed a solution for rev matching on downshifts.
We have a very detailed understanding of DBW signals and their interactions with the ECU.
Our modules provide a plug-n-play solution for manipulating commanded throttle position electronically.
Most applications involve a sequential transmission requiring a blip during downshifts.
Interface directly inline with the OEM APP (Accelerator Pedal Position) sensors.
Can be configured to trigger on any external input event.
Programmable Parameters
  • Target Throttle Blip %
  • Delay after trigger for blip (ms)
  • Duration of blip (ms)
  • Min. time between blips (ms)
    Technical Notes
    • Utilized OEM Throttle pedal connectors: Plug-n-Play No cutting or splicing of wires that can lead to limp mode issues
    • Passive design, vehicle operates normally when switched off.
    • Full telemetry via USB or set throttle % On-Board and forget it.
    • Every unit end-of-line tested
    • Made in the USA
  • FREE SHIPPING IN THE CONTINENTAL USA $525.00 USD
https://www.xplosiveperformance.com/DBW-Throttle-Blip-Modules_p_4251.html
XP Motorsports
Longwood Florida
sales
ford
Get free shipping on everything at XP Motorsports till 4/29/20
Status
