aleccolin
- Jun 7, 2017
- VA
- Website
- www.CarClubVT.com
- Colin
- 2016 GT PP
After a lot of research I've made a significant improvement in the way my car shifts/feels/drives with just three (relatively) cheap and simple mods.
1. Steeda 35 lb/in clutch pedal assist spring - Cost $20
https://www.steeda.com/steeda-s550-mustang-clutch-spring-assist-35-lb-in-15-16-all-555-7022.html
The previous owner installed the lighter clutch pedal assist spring and perch, but I drove several new S550 cars before this one and right off the hop, this is a big improvement in your interface with the car. If you only do one thing to your new Mustang, this should be it. I have the perch too, but this spring is significantly LIGHTER than stock, so a stronger perch is totally unnecessary IMO.
2. BG Syncro Shift II fluid change - Cost $85
https://www.opmustang.com/store/p4/..._Shift_II_Synthetic_Gear_Oil_-_MT82_Kit_.html
BG Synchro Shift II is leaps and bounds better than the factory fill, meets/exceeds Ford's specs, and I've been told some dealerships will put this in for customers complaining about their manual trans. While it can still be a little notchy when cold, as soon as its up to temp you'll fall in love. Certain tracks and backroads have you swapping cogs a lot, especially with 3.73s, so even though it's pricey for gear lube, it's worth it for cars that get flogged on a regular basis. Trans temps stay down on track too, cheap insurance.
3. Energy Suspension shifter bushing - Cost $18
https://www.amazon.com/gp/product/B01300AV6O/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
SO many guys spend BIG money on shifters, but there's a DIRT cheap mod that'll get you half way there while saving $400-500. This little guy only cost me $16 on Amazon and the difference was VERY noticeable. It's still the stock shifter, so the feel isn't going to be bolt-action rifle, but it changes the character and if Ford used this bushing from the factory there's a LOT of people who would never have bothered installing a shifter.
These three mods work so well together, for only $125 spent it almost feels like you're getting away with something.
Honorable mention: Steeda differential bushing insert kit - cost $100
This is less direct and more felt when launching the car hard repeatedly, but the slop in the diff mounting translates all the way up and you'll feel it as a "vagueness" in the clutch takeup. Most people do this for wheelhop, myself included, but it does do something for the normal/spirited driving experience as well.
