Cleaning honey comb grill
sebounet
montreal
2018 conv gt auto, var exhaust,shaker, safety pack
The worst part to clean for me is the honey comb grill, especially the holes that are not drilled. What do you use ? tools , products
Thank you
sebounet
sebounet
montreal
Texstang
'16 EB Premium PP 6MT
I use a paint brush style brush to clean the areas that are not cut out (the parts that you can't stick your finger through).
I also use a wheel woolie style brush (I use the smallest one in this set) to clean the cut out honeycomb pieces. They're also great for cleaning rims.
As for the cleaner, either a normal car soap/water mix would do, or if you need a bit more cleaning power, I would recommend using Meguiar's All Purpose Cleaner diluted with water 4:1.
PatrickGT
Chandler, AZ
2017 GT PP
I also use a brush (not a paint brush per se, I like a firmer bristle) or the smallest woolie.
Caution: Do not use any woolies/brushes on your paint/trim/etc that has touched your wheels.
Nightblue3
Riverside
2016 Mustang Ecoboost Premium PP, 2016 Mustang GT/CS
I use the pressure washer (rinse --> snow foam --> rinse) its pretty much enough for me. Just aim the washer nozzle on the area and it should get cleaned
