Boost leak mystery
lisandra
mama smurf
Puerto Rico
lisandra
ecoboost PP non premium
Ok so help me somebody. Smoke test it and nothing. Guy took it for a spin and told me it only leaks at about 70% throttle or over. Otherwise it builds boost beautifully until you go past that point, then you can actually hear the leak very loudly. Which makes him think its the wastegate or the bov (the wastegate???) How can i test my bov??
lisandra
mama smurf
Puerto Rico
lisandra
Solved. Check your vacuum lines too!!! Back to a happy 24 psi!!
AR306
2016 Shadow Black Ecoboost Base Auto w/ 19's
I was under the impression that this thing maxes out around 22lbs on stock tune.. I see 21.4 on a launch and 18-20ish under hard acceleration.
dragonacc
TN
2015 Ecoboost PP
Anyone care to weigh in on this? I'm completely stock with 1100 miles after 6 months and saw 21psi last weekend.
The ECU works on torque targets. It can adjust boost levels to hit those targets. Basically, there is not a set boost level for the engine, but there is an upper limit.
lisandra
mama smurf
Puerto Rico
lisandra
Anyone still having this problem have a look at boostleaktesters.com. awesome people, and the kits work.
