Boost controller help
Darinbranham
Ohio
Darin
2020 mustang GT
Big single setup.
I have a GFB controller and my wg springs are 4lbs I can only get 10lbs out of the controller. Someone suggested a manual controller like a hallman. I bought one and set it up it spikes to 13psi but falls back to 10psi is it a spring issue or something else?
aleccesarenriquez
San Antonio, TX
Alec
2017 GT PP
If you have a 3 port solenoid for the gfb, you should try purchasing a 4 port and replumbing. You'll be able to make more boost on less duty cycle. I'd guess you could make maybe 16 psi at 100% duty cycle with 4 lb springs. On board air or co2 are other solutions
Darinbranham
Ohio
Darin
2020 mustang GT
Is the manual controller have a limit also? I didn’t think they did?
4sdvenom
Fort Wayne, IN
Ken
2003 Mustang Cobra
I thought about 2.5 times the spring weight was about the limit for electronic boost controllers? (Not counting C02)
So a 4 lbs spring would get a maximum of about 10 lbs.
May just have to bump up to a 6 lbs spring to get a max of around 15 lbs, or an 8 lbs to max around 20 lbs.
Maybe things have changed, but that was the rule of thumb for electronic boost controllers as I always understood it.
Ken
Darinbranham
Ohio
Darin
2020 mustang GT
Ken
What about manual controllers?
4sdvenom
Fort Wayne, IN
Ken
2003 Mustang Cobra
I've never dealt with or looked into manual controllers since they were never an option I wanted to pursue.
I think your easiest fix would be to swap in a set of 6 lbs springs, or bigger depending on your plans.
