BMR Suspension Releases New Product - Motor Mounts for 05-Newer Mustangs - MM007
BMR Suspension
Seffner, FL
2015 300A PP GT
2005 and Newer Mustang Polyurethane Motor Mounts
MM007
Reduce engine movement and improve throttle response on your 2005 and newer Mustang with Polyurethane Motor Mounts from BMR Suspension. The factory mounts are designed to absorb noise and vibration for a smooth ride, but do little for performance. The BMR mounts are constructed from ÂĽ-inch, laser cut steel plate, aircraft-grade 6061-T6 billet aluminum, and 95-durometer polyurethane bushings. The BMR Polyurethane Motor Mounts (PN MM007) drastically decrease engine movement by replacing the soft rubber bushings with stiffer polyurethane bushings with little change in NVH. These mounts are also 50-percent lighter than factory mounts. Installation time is 2-3 hours. Available in black hammertone powdercoat.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
