Base GT 6 speaker system
MM6G
Gonzales, LA
Thomas
2016 Mustang Gt Magnetic
Has anyone just swapped out the stock - 6.5" speakers? Stage 3 sells a 4 speaker 6.5" Kicker -they say a big improvement over stock? Does anyone know if the rear speakers in a vert are also 6.5":shrug:
I changed out all my speakers to kicker but not from stage 3.......not sure about the verts but in the fastbacks front and rears are all 6.5's. I would recommend reusing the front speaker brackets like needed for the rear....stage 3 doesn't say so but without brackets you have to drill holes in the door and there's barely enough room to do so or go to a 6-3\4 for the fronts .
svtguy
Ontario Canada
2016 V6 Vert
Thanks,was there a big difference in the sound-before and after? Money well spent?
MM6G
Gonzales, LA
Thomas
Sounds better than stock as far as clarity ......yes money well spent .....I got the DC series kicker from Walmart spent $125 for 2 pairs mounted perfect ...
sauerkraut
Ohio
Justin
S550 EcoBeast
I swapped all of mine with pioneer TS-A series (3-way in front, 4-way in rear).
It sounds much better than the factory. The factory speakers had almost no low end bass, but the pioneers at least push enough air that I can feel it on my leg next to the front speakers. Truth be told; I listen to death metal so booming bass isn't what I was after though, just tight controlled decent bass.
Make sure whatever speakers you get have a high efficiency rating since without an amp, you'll want all of those (probably 10-15) watts to work for you.
ECM90
DC
2015 Ecoboost Mustang
How many watts total is the base setup pushing?
