Barton Shifters NOW AVAILABLE at Lethal Performance!
JakeLethal
Wellington, FL
Jake
2022 F-150 RCSB 5.0
Hey, All!
Barton Industries is now available here at Lethal Performance!
Specializing in high-quality, Made in the USA aftermarket Shifters, Handles, and other Drivetrain Accessories for Mustang, Challenger, and Camaro. With more than 30 Years experience in CNC manufacturing and metal working, we are proud to have their entire lineup available here at Lethal Performance!
Barton HYBRID 3 SHIFTER
The Hybrid 3 Shifter can be mounted directly to the transmission or mounted to the body, with a unique linkage design that can be installed as a solid linkage with the trans mount, or pivot with the body mount.
Features
  • 25% Throw Reduction for Short Smooth Shifts.
  • Dual Mounting Options to fit your shifting Preference.
  • Adjustable side to side spring pressure, dials you in for a perfect 2-3 shift EVERY TIME.
  • 3 Bushing System achieves the most accurate shifts on the market.
  • Little to no increase in Noise
  • Increases side to side distance between gears, for a more forgiving shift
  • The Most complete shifter on the Market
Check it out here!
SHOP NOW | Barton Industries 2015-2023 Mustang GT HYBRID 3 Shifter
Center Shaft Shifter Replacement and 2 Post Bracket Combo
As a more budget-based option for a short shifter, Barton offers just the center shaft replacement, along side their 2 post bracket. This reduces the throw 25% over the Factory shifter, while lowering the overall height of the shifter by 1 inch.
This is to ONLY be used on the Factory shifter casting.
Check it out here!
SHOP NOW | Barton 2015-2018 Mustang Center Shaft Shifter Replacement and 2 Post Bracket Combo
Barton GT350 SHIFTER
- 25% Throw Reduction
  • Machined from 6061 T6 Billet Aluminum and 303 Stainless Steel
  • Includes Billet Aluminum pull up collar
  • Will work with factory shift knob and pull up collar for “stock look”
  • Maintains the factory style “Pull Up” Reverse Lockout”
  • M10x1.25 Thread for shift knob (same as stock)
  • Note: Factory boot must be modified to use our pull up collar (optional)
Check it out here!
SHOP NOW | Barton Industries Short Throw Shifter (2015-2020 Shelby GT350)
Check out the ENTIRE Barton line-up here at Lethal Performance!
Of course, if you have any questions, looking for something in particular, or want to get something on order, feel free to reach out to any one of us here at Lethal Performance!
