B&O 12 speaker specs?
B-Mitch
NY
Brian
2021 Mustang GT
Hey guys, I've done a ton of searching and reading and I can't find any solid info on the B&O setup. I would like to put some JL 6.5 components in the stang, but I can't find how the factory system is wired. I read somewhere that someone thought the door woofer and midrange speakers are wired in parallel and the tweeters are separate... But he didn't sound very sure of himself. I can't find any sights that tell mounting depth availability or stock impedences or anything. I'm hoping to find someone who's actually done a speaker swap with the 12 speaker B&O. I've already installed the 12W7 off of a HD1200, and I need some crystal clear mids/highs to match.
Cathul
Germany
Peter
Ford Mach-E
If the B&O is wired the same as the Shaker then midrange an tweeter are wired together.
I don't know if something changed from the 2020 to the 2021 Mustang in regards to the wiring of the B&O system, but maybe you could get a Maestro HRN-AR-FO2 harness and work from there.
It gives you pigtails to connect your amps to the stock wiring for the speakers. Tweeter should get new wires though, which isn't too bad as it's not in the doors.
B-Mitch
B-Mitch
NY
Brian
2021 Mustang GT
I see that Crutchfield has it listed as fitting my car... Even though I can't find anywhere that says it works with the B&O system... I'll prob chat with them later today to confirm before buying. I also see that the dsr1 is out of stock everywhere, so I'll ask Crutchfield if that harness works with other companies dsp devices as well. It's just a breakout kit, so I don't see why it wouldn't, but that's a lot of $ to spend on a guess. Thanks for the info!!!
