Apex Torque available here at Lethal Performance!! Check it out!
JakeLethal
Wellington, FL
Jake
2022 F-150 RCSB 5.0
Hey all!
Apex Torque is available here at Lethal Performance!
Apex Torque is a sister company of Boundary Pumps, known for their high quality, high performance Oil Pumps, Crank Sprockets, and other Lubrication System Component.
Carrying a variety of high strength, superior quality fasteners for all sorts of popular engines, including Coyote, Predator, Modular 4.6, and even Barra!
Of course, they’re not limited to just Ford, as their lineup includes fasteners for Chevy, Honda, Nissan, Mitsubishi, and MORE!Main and Head Studs for Coyote!
Apex Torque stud kits are cut and rolled from billet steel containing their proprietary triple temper, 2 stage heat treat, and alloy combination.
  • Head Studs Available in both 11 and 12mm options for every variation of Coyote.
  • Ultimate strength of 280,000 PSI and reusable yield strength of 260,000 PSI.
  • Corrosion and scratch-resistant surface with 60 hours in a salt spray
  • Every washer and nut are perfectly matched to ensure the best distribution of load.
Check them out here!
Coyote Main Studs: Apex Torque Ford Coyote Main Stud Kit - CM-MSK (AXT-CM‐MSK)
Head Studs
11MM : Apex Torque Ford Coyote 11MM Head Stud Kit - CM-HSK-11M (AXT-CM‐HSK‐11MM)
12MM : Apex Torque Ford Coyote 12MM Head Stud Kit CM‐HSK‐12MM (AXT-CM‐HSK‐12MM)
Coyote Harmonic Balancer Stud Kit
Apex’s harmonic balancer stud kits feature one of the world’s strongest alloys, AT280, providing an unmatched safety and fastener performance!
  • Massive oversized 1-1/4 nut with full 1-1/2 inch flange to distribute the stud load
  • 280,000 PSI Ultimate Strength
  • 250,000 PSI Yield Strength
  • Dual External Coating Technology combines 500+ hours of salt spray endurance in the threads with 3000+ hours on the rod.
Check it out here!
Coyote : Apex Torque CM‐HBB Coyote Harmonic Balancer Stud Kit (AXT-CM‐HBB)
GT500 : Apex Torque CM‐HBB-GT500 Coyote Harmonic Balancer Stud Kit (AXT-CM‐HBB-GT500)
Check out all the Apex Torque has to offer HERE!
https://www.lethalperformance.com/search/?q=Apex+Torque
Of course, if you have any questions or want to get something on order, feel free to reach out to any one of us here at Lethal Performance!
