APEX Head studs in STOCK @ Beefcake Racing!!!
beefcake
Bethel
2018 Ford Mustang
We just got the an order of the Apex Torque 11mm Head Studs (Ford Coyote) CM-HSK-11M.
https://www.beefcakeracing.com/apex-cm-hsk-11m/
Description
The Apex Torque stud kits are cut and rolled from billet steel containing our proprietary triple temper, 2 stage heat treat, and alloy combination. This material gives an ultimate strength of 280,000 PSI and reusable yield strength of 260,000 PSI. We don’t stop with a strong part; every piece of our hardware is wrapped in corrosion and scratch-resistant armor creating a surface that resists corrosion for 60 hours in a salt spray and can be dropped and abused without worrying about a corrosion failure down the road.
  • Each piece of hardware in these kits is cut from billet. Not stamped, not forged, not cast, but made from the densest and strongest form of steel, right from the foundry
  • Each piece of hardware: nut, washer, and the stud is made from the same super-strong material, and heat-treated to the same level to ensure no part of the fastener stack fails
  • Every washer and nut are perfectly matched to ensure the best distribution of load.
  • Each batch of heat treatment is tensile tested to ensure the fasteners in those loads reached the correct amount of strength, and that data is recorded onto your sets individually assigned quality paperwork.
  • Every thread is gauged, nut and stud, to ensure smooth torque loading and strong thread engagement
Feel Free to DM me or call with any questions.
Terry "Beefcake" Reeves
Office - 855-TBR-RACE
Owner Team Beefcake - 20+ Years Experience
Deal Directly with the boss, no pushy sales guys!!!!!!!
https://www.beefcakeracing.com - Your Forced Induction Specialists
#beefcakeracing #teambeefcake
