paullyd210
- Feb 7, 2015
- San Antonio
- Paul
- A ticking time bomb ;)
Started my heater for the first time, noticed the passenger side wasn't heating but the driver side was. I knew immediately it was a blend door actuator. Took it to Ford it was indeed an actuator and also just as I predicted the parts on back order. Good thing I don't drive with passengers often so I'll just shut the passenger vents when the heater is on.
Purpose of this post is more informative than anything else. The only reason I noticed was because I just so happened to have the center passenger vent pointed my way. Had that not been the case, I probably wouldn't have recognized it. So it wouldn't be a bad idea to check yours just in case and take it to the dealer if necessary. It's an easily identifiable issue and depending on how busy your dealer is and if you take it in early in the morning you should have you car back in a couple of hours or the next day at the very most.
Who knows I may be the only guy with the .001% chance of a manuafacturing defect considering 113,607 (not verified just copied from another thread)total sales thus far it adds up perfectly. That just means at least one other person is probably out there and this post is for you. Haha
