olaosunt
Thanks again man.I am sure you already did, but i would talk to your engine builder before you go any further. The way i am taking what you are saying is you had a factory 5.0l block bored and sleeved to 5.2l. I can't see how those head gaskets you say you used would be correct since the 5.2l block has different coolant passages at the very least. It really doesnt take much to restrict oil to a head, or to bleed off pressure. Where was he measuring the pressure at the head?
My installer said when the pressure at the sending unit was 30 psi it was 5 psi at the right head .
I definitely will .My installer had initially raised some concerns when I said I was going to be ordering the head gaskets for the Shelby GT 350 ,as he was not sure it would fit .MMR had said the regular 5.0 head gaskets would work with the heads but that the GT 350 gaskets " were only recommended when using the heads on a 5.2 bore"
They did not specify if they meant a bored out 5.0 or the Shelby block .
I assumed he would be able to tell if those gaskets were the right ones before assemblying the block .
