Chargedguard5.0
Thanks for the info. Can't wait to get the car back to start messing with it.I use an MSD 2 step, set on 3300rpms, cut 1.4's on 20's. The best thing you can learn about your BL is the Rate feature. Rate determines how fast you bring in the boost, your solenoids take over at 3psi and you can control from there. The days of "boost lag" are over, I hit 21psi/1000whp+ in 1 sec flat off of my launch, then bring in the Rate over 2 stages. 50 is the max setting for BL, which is what you should always use when on the dyno, or you won't make as much whp/tq if it is on a lower setting. You don't want to run 50 on the street or you'll blow the tires off on any boost level. Then, try to find your happy medium with Rate, you want as much Rate as possible without losing traction. If you are losing traction then turn your rate down, keep boost at a constant till you can find the cross roads of max/peak boost with as much Rate as possible, without spinning. That's a lot to take in, but you NEED to become one with your BL, specifically the Rate.
I helped a guy at the strip this weekend with his BL, improved his best et's by .3 in 2 passes, just by showing him how to adjust his Rate.
