Annoying noise inside passenger side rear panel
MaxQ
2016 Oxford White 5.0 GT
I have had this annoying noise coming from inside the passenger side rear panel ever since I have the car.
today I stripped the inside to install my rear seat delete project.
and found the source of the noise. there are 2 blocks of polystyrene foam
inside the rear quarter panel attached with spring clips, however the foam is broken away from one of the clips so it doesn't do anything.
( rub 2 pieces of foam together and you get my noise)
I have now glued them in place so hopefully fixed the issue.
Foam block
TeamDenno
Sydney
S550 GT V8 Manual
Brilliant!
I think a few of us have similar issues and problems!
Hellman109
Melbourne, Australia
2017 Mustang Ecoboost Convertible (See my garage)
I had the same annoying noise but I just deleted the passenger.
It's quite now... :thumbsup:
Ive heard of the rear seat delete, but never the front passenger delete ;)
TeamDenno
Sydney
S550 GT V8 Manual
MaxQ
MaxQ
Ok went for a drive today and all is well, seems the fix has worked
we will see how it goes in the long term.
stang_86
Canberra
Range Rover Sport, 2016 Mustang GT 2019 Bullitt
I have the same issue seems it happens on rough roads.
Might pull it part when I get a chance
Australia, MELBOURNE
Ange
2017 Mustang GT PP, Magnetic Grey
Foam block
Did you have to pull out back seat to remove side trim?
MaxQ
MaxQ
Hi, You would need to remove the rear seat base however not sure if you need to remove the back, would be easier if you did, 15mm socket required.
there is a video from LMR explaining how to remove the trim pieces for the rear seat delete kit
link below
Hope this helps
[ame]
MaxQ
MaxQ
Is it a squeaking sound?
Hi, sort of a rubbing sound as opposed to a rattle sound if that makes sense.
I had someone sit in the back and when the noise was present they push on the panels to stop the sound, that how i located the area to look further.
control4userguy
Los Angeles
2018 GT Premium
Rear side trim is not very well anchored by design. I saw that when I removed mine. No need to remove rear seat back, doesn't really make any easier to remove panel...
