Adding Line Lock
StangATX
Project Corrupted Cyclone
Austin, TX
2016 S550 White Corrupted Cyclone
Here's what I tried so far...
Original (2016 V6): 0200 016E (Same part # as 2016 GT PP)
2016 GT PP: 8600 7364 (Same part # as Original) Writing Block 2 Failed - Incompatible configuration
2015 GT: 0200 329F Writing Block 2 Failed - Incompatible configuration
2017 GT: 0200 69D6 (Same part # except the end that finishes with BD instead of BC) Writing Block Failed - Incompatible configuration
2017 GT PP: 0200 329F (same as 2015 GT)
2017 GT: 0200 329F (same as 2015 GT and 2017 GT PP)
I really wonder if the value 760-02-02 in the ABS is Line Lock now...
They all failed except this one: 760-02-02 0200 319E (But as we reported before it throw an Advance track error). I had to clear my DTC because I had the ranch to check the manual that kept showing up even after I put the block back to stock...
Quick update: I've got an idea and here's what I've come up with...
I took the value: 8600 7364 (I know I said it didn't work. Except that I changed it) Here's exactly what I injected in the ABS:
760-02-02 8600 01F2 (Here's where it becomes interesting! Forscan took it without any error and the Advance Track didn't trip! This could be the correct value somehow... I tried my car in my drive way and I put it on Neutral to check if I was on flat level. The car didn't move even though for me it didn't seem flat lol). I thought it'll be interesting to throw here all the values that we tried and it doesn't get any errors...
Here's a screenshot:
Bazzie
Belgium (Limburg)
Mustang ecoboost
Hi,
On my EURO-ecoboost I have these as-built-values:
ABS: 760-02-02: 8600 1809
IPC: 720-??-??
Is there is more known which values ​​directly into the modules 720 and 760 should be changed?
Thank from Belgium
