1badrz28
My tire moves around the rim. Not sure if its because of how they were mounted or some type of lube they may have used or what. Every drag mode 1-2 shift on the street they move like a quarter inch, so they cant be balanced. The tires I am using are the MH racemaster 325's. Kind of annoying but not really noticible until above 80 mph then its just a bit of a vibration.
Next set of rear tires, add Permatex Hi Tack to the cleaned tire and bead area and your movement will stop. Usually, the Ru Glyde tire paste they apply enables the bead movement. You can also have them re-clean the tire and bead area before adding air to seat the bead which will also help prevent the tire movement. I like the added benefit of the Hi Tack, just to make sure there is no movement.
