Pennsylvania 2017 GT350 $56,000
wilddog
Oley, PA
GT350
Fair Weather Car, 26,800 miles, never been tracked.
Original Gen 1 engine. Does not burn oil
Serviced and Inspected in June 2024
Paint Correction, Modesta BC-05, 10 yr Ceramic Coating
Suntek front bumper film bra
Signature SV501 Monoblock Wheels, Michelin Pilot Sport 4S tires, 305 F, 325 R
OE Rims with Michelin Pilot Alpin Winter Performance tires, 295 square
MGW Shifter
QA1 1 piece carbon fibre driveshaft
Borla Attack exhaust system
Oil catch cans, jacking rails, hood struts, clutch spring, various Steeda and BR bushing kits
Diode Dynamics bulbs throughout
Body Color Engine covers
DCTMS custom leather steering wheel
All original take off parts come with car
Delta5
VA
Superduty
Nice looking car. What were the reasons you swapped the wheel and the driveshaft?
wilddog
Oley, PA
GT350
The carbon fiber driveshaft reduces weight and provides better torque and strength over steel. I was doing the exhaust and the MGW shifter and thought it would be a good time to do it.
The steering wheel was changed because I have some arthritis in my hands and the leather wheel is thicker and more comfortable.
The billet wheels were changed to reduce rotating weight. They are only about 2 lbs heavier than the carbon wheels
Delta5
VA
Superduty
Thanks for the info. Didn't see a notification, was cruising the forum and saw this.
Does the car burn any oil? If so, what rate of burn are you seeing?
Any issues with the car that you've had to fix?
wilddog
Oley, PA
GT350
Initially, when the car was new I added a quart between oil changes. In the last year or two I have not had to add any oil. I am a spirited driver, but don’t hammer the car. The only non maintenance item I’ve had is the recall for the back up camera sporadically not working. Everything else has been normal maintenance.
furdfan2018
AZ
Mustang
Good Lord that thing is nice. GLWS!
