Norm Peterson
corner barstool sitter
What it appears to do is get around the CB limitation of choosing between anti-squat and roll steer & bump harshness. The SVIC (IC to drag racers) will be along the dotted line identified as the "side view inclination of lower control arm in the linked sketch.Less wheel hop than the traditional SLA IRS because the vertical movement is controlled/limited with the I Link.
It looks like the other construction line for determining the SVIC runs through the IL upper pivot and is parallel to a line drawn through the IL's lower pivot and the knuckle's other pivot at the LCA. That would put the SVIC at some distance ahead of the axle line and above the axle center height, and reduction in wheel hop would be for that reason.
The various bushing compliances will modify this somewhat.
As kind of a side note, the actual knuckle translation would be somewhat closer to vertical than the arrow depicts.
Norm
