- Oct 7, 2014
- California
- Website
- www.modularmotorsportsracing.com
- Worlds Fastest & Only 5 second Coyote
If you have found this product you have either broken your factory differential bushings and are not interested in buying a complete subframe since Ford does not sell the bushings separately OR you have tried the Solid or Polyurethane Bushings and hate them like 99.9% of those that purchase them (huge noise and vibration).
Bottom Line, this is not a fun job and not one you want to do twice!!!!
Enter the MMR Diffrential Bushings. This Bushing kit has been engineered by MMR and Manufactured in Germany of Strong Upgraded Rubber with Billet Inserts to get rid of all of the factory bolt "slop" and yes, this is not just a replacement, it is a performance upgrade with a Lifetime Warranty.
The MMR kit does not use inferior hardware with nuts and lock washers like the copycats. This is a professionally engineered kit that includes upgraded Bolts!
Features:
Lifetime Warranty to Original Owner
Performance Upgrade
Increases Driveline and U joint life
Upgraded Rubber design provides strong, quiet performce compared to other brands.
Does not use cheap hardware store bolts, nuts and lockwashers !! - MMR's kit includes Extreme Strength Hardware
Notes: Installation requires subframe removal from vehicle. This is a time consuming job that requires removing and installing the differential bushings with special tools (MMR suggests a hole saw and air grinder to split the factory bushing for easy removal)
Order here: https://www.modularmotorsportsracin...n_page=product_info&cPath=94&products_id=1597
Features:
Performance Upgrade
