2015-2018 Camber Plates - VIKING STRUTS ONLY
UPRSteve
Lake Worth, FL
www.uprproducts.com
15 GT
THESE ONLY FIT VIKING FRONT COIL OVERS - WILL NOT WORK WITH FACTORY STYLE STRUT
New from UPR the 2015-2018 Mustang Caster Camber Plates for Viking Coil Over Struts. Our caster camber plates replace the stock flexible strut mounts allowing you to install Viking Coil Over Struts for a fully adjustable from end and giving you better control of the front suspension geometry.
Features Tig welded construction, Fenlon PTFE lined bearing, Stainless steel bushings spacers and bearing/stud plates are Nickel plated for a durable yet clean finish.
FEATURES:
» 1 to 1.5 Hour Install
» Fenlon PTFE lined bearing
» Adjusts both Caster & Camber
» High Quality CNC Machined Steel
» Bearing & Stud Plate Nickel Plated
» .250in Thick Steel Caster Camber Plates
» Fits Viking Coil Over Struts Only! (J205, J215, J225, J235, J305, J315, J325, J335)
These list for $239.99
Can be found here:
http://www.uprproducts.com/mustang-steel-caster-camber-plates-15.html
