CJ Pony Parts
- Dec 21, 2015
- Harrisburg, PA
- Website
- www.cjponyparts.com
- A large variety of Mustangs across all generations
Just like any retail business, from time to time we get returns. A lot of times there is little to nothing wrong with the actual product and more often than not a customer just changes their mind. Luckily we have our eBay Store which will allow us to pass on great savings to people that aren't worried about a possible scratch or dent, maybe a missing washer, nut or even instructions.
If a used, returned or discontinued item is posted on our eBay Store, we try to take as many photos as possible and explain what (if anything) is missing and/or damaged. Below is a perfect example of this.
2015-2017 Mustang V6/EcoBoost/GT 25mm Wheel Spacer Pair Aluminum Hub Centric
Item condition: New other (see details)
"These were previously installed."
Original Product Listing:
Pair of Silver Billet Aluminum 25mm Hub Centric Wheel Spacers for all 2015, 2016 and 2017 V6, EcoBoost and GT Mustangs.
Ford is always very conservative when determining the offsets and backspacing for the wheels that will come equipped on your Mustang from the factory. Even with the larger 19” and 20” wheels that are available now, you will notice how much the wheels sit tucked in and lose that aggressive muscle car look.
CJ Pony Parts is proud to offer you a safe and affordable solution that can easily give your 2015-2017 V6, EcoBoost or GT Mustang that perfect performance and visual touch. These are specifically designed to give your newly acquired Mustang a much wider and more stable stance that will push your factory wheels and tires out to sit perfectly flush with the fenders. They are also a perfect match for any of the Lowering Springs that we offer. Once you install these 25mm Wheel Spacers your S550 will instantly take on a much more aggressive look, with your wheels and tires filling the wheel arches exactly the way they should.
Features and Benefits:
- Ideal 25mm (0.984”) Thickness for ALL OEM Wheels and Tires
- Easy Installation that will Widen Your Stance for Better Handling
- Aircraft Quality 6061-T6 Billet Aluminum Construction
- Precision Engineered 70.5mm Hub-Centric for Perfect Fit and Wheel Balance
- Features Correct 5x4.5” Bolt Pattern and 14mmx1.5 Metric Thread Pitch
- Kit Includes (10) Lug Nuts that will Allow Your Wheels to Seat Properly
- Sold as a Pair
*These wheel spacers are NOT designed to be used with the GT350 and GT350R.
Please Note: Aftermarket wheels may not work with wheel spacers depending on the size and the design of the mounting face. Offset/backspacing variations may also affect fitment.
Wheel Spacers will allow you to position your wheels and tires exactly where they will perform and look their best. Dialing in the track width will not only enhance your Mustang's looks, it also improve the handling performance and optimize roll characteristics. In most situations, installing the correct wheel spacers can improve the look and function of your existing wheels and tires so much, you may not feel the need to buy new custom wheels and tires at all.
THIS IS A FINAL SALE THERE WILL BE NO RETURNS OR REFUNDS ON THIS ITEM.
- Sold as a Pair
