2015-2017 Ford Mustang GT Kooks Long Tube Headers 1-7/8" With Catted Mid- Pipe 3" Stainless Steel
RPI Designs
Gold Sponsor
Salem, Ohio
www.rpidesigns.com
2015 Mustang GT - Test Mule
2015-2017 Ford Mustang GT Kooks Long Tube Headers 1-7/8" With Catted Mid- Pipe 3" Stainless Steel $1663.07
Discover the hidden horsepower gains in your 2015-2016 Mustang's 5.0L coyote engine with the best long tube headers on the market. Kooks long tube headers are made from aircraft quality T304 stainless steel. Kooks only uses the highest quality stainless steel, unlike their competitors. 1-7/8" tuned primaries merge into 3" collectors to create the smoothest flowing path. Every collector features Kooks' scavenging spike to ensure maximum flow. Laser cut 3/8" thick flanges ensure no warping or bending occurs. Each port is hand ground to make sure they are perfectly smooth so there is no exhaust constriction. Kooks systems are bolt-in and never require any cutting or welding. O2 extensions, bolt-in catless off-road mid-pipe, and all necessary hardware are included for an OEM-like fit and finish.
Features and Benefits:
- Full Stainless Steel Construction
- Includes Blot-In Mid-Pipe
- Catted Design
- Retains OEM Connections
- CNC Mandrel Bent Tubing
- 1-7/8” Primaries into 3” Collectors
- Scavenger Spikes ensure Maximum Flow
- Maximum Horsepower Gains over Factory Manifolds
- Made in the USA
Each Kooks exhaust system is designed specifically for the engine and vehicle it is built for. Kooks utilizes the firing order of the engine when designing their exhaust tubes. The most technically advanced equipment is used when designing Kooks exhaust systems. Every system is dyno and race tested to ensure the results are up to Kooks' expectations. This means Kooks can guarantee their exhaust makes the most horsepower and torque in the industry. All Kooks products are manufactured in a 45,000 square foot state of the art facility located in Statesville, North Carolina. A tune is required.
https://www.rpidesigns.com/shop/item.aspx?itemid=5143
Advertisement
20 - MAK Performance - 1
Advertisement
